Platform: J-body
overheating
Old Feb 27, 2014 | 9:17 AM
  #11
bugrollei's Avatar
Its all back together.. Running it the temp hand goes to 2 marks pass 195 when stopped it goes up to 3 marks... I am going to get a new temp sensor and when it warms outside up do a complete clr flush.. I will update will all later.. Thanks!
Old Feb 27, 2014 | 7:52 PM
  #12
bugrollei's Avatar
So was driving it more... It runs fine on highway and as soon as I get on side roads goes to 3/4 to red.. so will get a new cap and sensor..
Old Feb 28, 2014 | 8:55 AM
  #13
BW56's Avatar
Try driving on the side roads in a lower gear to keep the rpm's up. DONT over do it. If it runs cooler let us know. Mine did that and if i kept the rpm's above 2500 it ran cool. At idle it would creep up like yours. I still think you should bundle up and bypass the heater core and test drive it. Ohio ?* vs Arizona 77* sorry this is the only time of the year we can brag about the temperature.
Old Mar 4, 2014 | 6:08 PM
  #14
bugrollei's Avatar
Go Reds!!
Old Mar 8, 2014 | 6:29 PM
  #15
bugrollei's Avatar
I changed the cap on the tank today and no change.. I am going to change the t-stat again maybe tomorrow.. I got the new sensor and will drop that in.. The hose coming off the t-stat is still cold and the radiator is cold..
Old Mar 8, 2014 | 10:18 PM
  #16
I'm betting its another clogged heater core. How many times have we seen that eh bw56. its usually the last thing to get considered and maybe rightly so...it just doesn't seem like it should be the cause but usually it is for this vehicle.
Old Mar 9, 2014 | 2:51 PM
  #17
BW56's Avatar
If SHE'S not careful she's going to pass me on the number of things i did trying to fix mine. I documented my efforts on here in 2011. "2002 still getting hot after changing everything" They haven't made cars any easier to work on for the little guy either. Mines still running. How can i make a link to my old thread? Links for dummies didn't work.
Old Mar 9, 2014 | 10:00 PM
  #18
sledge.impy's Avatar
Was the thermostat installed the correct way?
Old Mar 12, 2014 | 5:07 PM
  #19
BW56's Avatar
On mine that's the one thing GM did right. They made it so idiot proof it only went in one way.
Old Mar 13, 2014 | 8:08 AM
  #20
bugrollei's Avatar
I did by pass the heater core and the weather here is bad again (ohio).. I will try to run it this weekend..
FYI: For BW56 I am a she..
" he's not careful he's going to pass me on the number of things i did trying to fix mine." Woot woot..
