Override anti theft?
you need to do a theft deterrent relearn procedure. 10minute one if you have a scan tool. 30minute one if you don't have a scan tool that can access the bcm. (10minute relearn is repeated 3x)
if the relearn doesn't work...you need to have the dealer program it. jbody.org a cav forum will have the relearn procedure.
ty, I appreciate that
Relearn procedure: Try to start car - when car doesn't start, leave key in ON position until theft light on instrument display goes out (10~15 min, I think) - repeat this process three times - after that car will start and will continue to start normally thereafter.
