Platform: J-body
are all cavalier starters the same?
Old Apr 9, 2020 | 12:13 PM
Bozo's Avatar
Default are all cavalier starters the same?
I have a 2001 2.2 5-speed manual transmission coupe. I am getting all sorts of conflicting info about whether starters are different for models with auto trans vs manual, or other variables. A lot of places don't ask about this and I hate the thought of getting under there with a new starter and it doesn't fit/work.
Related to that - do I have to deal with removing the bell housing cover or not? That is another area where I get all sorts of different answers. Some make it sound like the starter just slides right in with a few bolts - others make it sound like it is a nightmare and you need all sorts of special attachments and long extensions to reach the bolts for the housing cover. What is the story?
thanks
Old Apr 9, 2020 | 7:41 PM
go to rock auto build the 2 cars and compare part numbers.
Old Apr 10, 2020 | 1:19 AM
Jiyu's Avatar
Disconnect the battery, remove starter, take it to parts store and match it up with the new one (not a rebuild, a new one). Or pull it off in the parking lot of the parts store!
Old Apr 11, 2020 | 11:45 AM
Bozo's Avatar
Surely there is some place that lists all the cross-reference numbers. I have searched for a starter using my car's specs on a bunch of different websites, the copied and pasted all the numbers to a file - there are at least 40 different numbers. And the problem is that some sites say a number will fit and I'll go to a different seller, type in that number, the starter comes up, but it says it doesn't fit. And the prices range from about $35 to about $200 so I am trying to find out if the less expensive ones are the same/identical but because the numbers are all over the place, it is next to impossible. GM Part Number: 10465459
Old Apr 11, 2020 | 8:04 PM
Jiyu's Avatar
It's a 20-yr-old car - only way to be sure is to take it off and compare - cheap starters don't last.
ronald wilkins
Apr 7, 2017 8:47 AM
flattire
Feb 26, 2017 3:44 AM
abob
Oct 21, 2013 12:14 PM
leogirl42
Sep 9, 2011 11:58 AM
drive65
Dec 24, 2010 2:04 PM
