Platform: J-body
P0300 diagnostic code given?
Old Oct 6, 2010 | 4:57 PM
jen2swt's Avatar
Default P0300 diagnostic code given?
I'm having a really hard time trying figure out and pin point what the problem could be. This is what is happening with the car 2003
Sputters
Smoke (white) put put out of the exhaust pipe while driving
Can not get up to speed or accelerate
Car shakes
The readings we got were P0300 and it indicated O2 sensor, Catalyst, Comp and Fuel
We found the 02 sensors. What would you suggest? Can all of these be replaced ourselves? I know the O2's can. What about the Catalyst?, not sure what Comp or fuel is.......
Thanks for any suggestions.
Old Oct 7, 2010 | 8:34 PM
Segfault's Avatar
Are you losing coolant? White smoke usually indicates coolant is in cylinder(s). Which, in turn, usually means head gasket is blown, often because of warped head.
Old Nov 8, 2010 | 2:11 AM
mikeschopshop's Avatar
you cannot replace catalyst unless you are certified and only if it is damaged. the catalyst is your catalytic converter. it legially cant be replaced unless it is damaged.
Old Nov 8, 2010 | 8:41 PM
MDTAHOE's Avatar
Professional Mechanic
Where did you hear that? Anyone can go into any parts store and buy a cat. No one asks why.
farr52
Oct 13, 2010 1:46 PM
mkabwilliams
Jan 17, 2008 2:22 PM
justthefacts
Oct 18, 2007 12:49 PM
07TahoeLTZ
Mar 30, 2007 11:51 PM
warrennaujalis
Oct 28, 2006 10:24 AM
