Platform: J-body
replacing brake fluid
Old May 19, 2007 | 1:25 AM
02blue1's Avatar
Default replacing brake fluid
Hello, my wife drives a 2002 cavalier Ls. I would like to replace the brake fluid as preventative maint. I'm from old school method of pumping brake pedal and opening bleeder till pedal hits floor then close bleeder and let pedal up and repeat several times. I've read many articles as to how this method can be damaging to ABS systems. How would you go about bleeding the new fluid into the lines. would you need some kind of pressure bleeder or will the pumping pedal method be safe? also with car running or off?
Old May 19, 2007 | 5:17 PM
ruffrider285's Avatar
Default RE: replacing brake fluid
just unplug the abs and do it your way, then it wont mess with the abs. The abs plugs are right behind the rotor. Very easy to get to.
Old May 19, 2007 | 5:36 PM
Cavigurl85's Avatar
ORIGINAL: ruffrider285
that's exactly what me and my boyfriend did unplugged the abs i didnt want to plug the abs back in since i cant stand abs but we did anyways
Old May 19, 2007 | 5:51 PM
MalibuMaxxSS's Avatar
even unplug it in the evening and let it sit overnight then you wont have to press hte pedal it will just drain...loosed the cap under hte hood first
Old May 25, 2007 | 1:49 PM
jlenko's Avatar
Bah, the ABS system in the J-car is so simplistic, you couldn't hurt it unless you used a hammer to smash it with
I use a vacuum bleeder on the valves to pull the fluid thru. $20, and you can do it yourself... no need to rely on someone else pumping at the right times
...j
tbb2
Aug 4, 2015 11:23 AM
Slobby Baymon
Nov 12, 2013 11:52 PM
DeHartShadow
Mar 28, 2010 10:10 PM
junklady
Oct 28, 2009 6:01 PM
