Platform: J-body
Rough idle/hard start
Old Mar 2, 2021 | 6:03 PM
Zfurrr's Avatar
Default Rough idle/hard start
I’ve been plucking away at some work on my girlfriends car-1999 Chevy cavalier 2.2l. I’ve changed a fuel filter spark plugs/wires, and the coil packs. The plugs and coils made the car run a lot better all around but it still shakes quite a bit without a foot on the throttle, as well as won’t start unless you tap the gas. Was thinking of trying fuel pump next but didn’t make sense as the car runs great at all speeds. Any help is appreciated.
Old Mar 3, 2021 | 6:54 AM
Welcome from Florida. Try cleaning the throttle body and look for vacuum leaks. Cracked/brittle vacuum hoses are a possibility.
Old Mar 3, 2021 | 2:47 PM
Jiyu's Avatar
If you have to tap the gas pedal it's running lean (getting too much air/not enough fuel) So:
IAC (Idle Air Control Valve) Clean/replace
Vacuum leak
Clean MAF (Mass Airflow Sensor) See YT for info
Check air cleaner
If none of that helps do a compression check.
conanthebarbarian
Aug 17, 2024 4:22 PM
squarefan13
Apr 10, 2014 8:43 PM
gabhanjacisa
May 20, 2010 7:06 PM
warrior_oh58d
Jan 23, 2009 4:08 PM
mphayes
Jun 30, 2008 6:03 AM
