Platform: J-body
sound system help
Old Sep 28, 2007 | 11:11 PM
ruffrider285's Avatar
Default sound system help
I have a sony explod 1200 watt amp XM-2002GTR
(2) kicker dual voice coil 2 ohm subs 12inch...
What is the best way to wire these up to get the best possible bass and sound? Series or parallel?
Old Oct 1, 2007 | 4:20 PM
SmokinTaco's Avatar
Default RE: sound system help
when i did my girlfriends car i briged two 12 subs and 1000wat amp
[align=center] [/align]
Old Oct 7, 2007 | 1:49 AM
02blue1's Avatar
dude, you'll never see 1200 watts out of the sony explode. it will EXPLODE before that ever happens! you're gonna need a lot more juice for those kickers. sure, it will work but you're going to need higher end to get full wattage from the kickers. Dual voice coil subs usually are 8 ohms. i never worked much with kicker so i could be wrong. they do sound good though. if you parrallel two of them you'll get 4 ohms, and i think if you parrellel 3 of them you'll get like half on ohm but you'll need an incredible amp for this. only way you're gonna get 2 ohms is to buy two single voice coil subs rated for 4 ohms each and parrellel them after the amp. if you want 2 ohms from two dual voice coil subs at 8 ohms each you'll need an amp capable of bridging at the outputs off the amp and parrallel both subs. the circuitry of the amp is set up for this and will specifically say you can bridge off amp output. do yourself a favor and get a stiffening cap (lightning cap) also known as a capacitor. i would get at least 1 Ferrad or you're gonna see your headlights flashing everytime the bass hits. I used to install for circuit city. just stop by there or best buy and they can help you figure out how to wire your subs, it gets real fun, trust me!!
Old Oct 7, 2007 | 10:32 AM
I figured it out thanks. I used this wiring http://www.the12volt.com/caraudio/wo...p?Q=2&I=22and i picked up a kicker zx1000.1 for an amp. Thanks though
jeffcool
May 16, 2015 6:48 PM
atm0001
Jul 13, 2007 1:34 AM
