Platform: J-body
Strut and Fender Replacement, Please Help
Old Sep 1, 2010 | 8:17 PM
magnato1's Avatar
Default Strut and Fender Replacement, Please Help
Hey all,
My girlfriend has a 2004 sedan and the front passenger side fender has some damage to it. If I can find a good one in a junk yard, how difficult is it to remove and then install? Does it require riveting or anything weird like that or is it just bolted in place?
Regarding the struts. She was told recently that her struts need to be replaced, car has about 90k, so I figure it's time. I'd like to do it myself to save money. Anyone know the procedure? Are they a coilover sort of thing? Will I need to remove the springs to do the struts or can I just jack it up and loosen the bolts and change em out?
I'm new to the forum and look forward to your help! Thanks!
Old Oct 5, 2010 | 1:48 AM
magnato1's Avatar
Really? Nobody has any insight on this?
Old Oct 6, 2010 | 9:27 AM
Poppop's Avatar
The fender is all nuts and bolts. Metric of course. Try to find a car with the door off to make it easier and it should be no problem. For the struts you have to have a spring compressor and it's best to get it aligned after the installation. Pretty simple otherwise and if you get the struts from Advance Auto Parts you can probably borrow the correct spring compressor from them.
Poppop
Old Oct 14, 2010 | 12:22 AM
magnato1's Avatar
Alright poppop, thanks for the info. I really appreciate it. I guess I'll start looking for a fender and some struts.
Old Oct 14, 2010 | 6:31 AM
nomad76's Avatar
for the struts find a car thats siting on the ground with the wheels on it so you can bounce it up and down to see how bouncy it is also check the milage as for taking them out three bolts under the hood and two behind the wheel loosen the three under the hood then remove the 2 behind the wheel so that it hangs there then remove the 3 under the hood, hope this helps
in2pro
Oct 29, 2013 5:32 PM
Helushka
Oct 26, 2013 5:32 PM
scooter22
Feb 15, 2012 9:56 AM
inbizness
Sep 29, 2009 11:06 PM
