Platform: J-body
Thermostat anf manifold
Old Apr 29, 2010 | 5:32 PM
Segfault's Avatar
Default Thermostat anf manifold
Do I have to remove the exhaust manifold to replace the thermostat?
Old Apr 29, 2010 | 8:05 PM
MDTAHOE's Avatar
Professional Mechanic
What year? What engine?
Old Apr 30, 2010 | 6:11 AM
Segfault's Avatar
2003 2.2 L
I think the thermostat is right under that exhaust manifold?
Old Apr 30, 2010 | 10:42 PM
MDTAHOE's Avatar
This is right from the service manual. There were pictures but I do not know how to post them.
If equipped with an automatic transmission, remove the exhaust manifold.
Drain the cooling system.
Remove the thermostat housing to water pump feed pipe bolts.
Remove the thermostat housing to water pump feed pipe.
Remove the thermostat.
Installation Procedure
Install the thermostat.
Install the thermostat housing to water pump feed pipe.
Notice: Refer to Fastener Notice in Service Precautions.
See: Service Precautions\Vehicle Damage Warnings\Fastener Notice
Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 10 Nm (18 inch lbs.) .
If equipped with an automatic transmission, install the exhaust manifold.
Fill the cooling system.
Old May 1, 2010 | 7:00 AM
Segfault's Avatar
Thanks! Thermostat, here I come ...
Old May 13, 2010 | 10:02 AM
Segfault's Avatar
Today I finally had time to take care of it. I couldn't get off exhaust nuts. Instead of soaking them and waiting I decided to give it a try without removing the manifold. Turned out it's possible, I was able to get that pipe out from there!
Yes, it is a 2.2 OHC with automatic transmission.
DVS95Lumina
Dec 24, 2015 3:57 AM
Black 5.3
Oct 29, 2006 2:45 PM
Black 5.3
Aug 10, 2006 4:14 PM
vofsar
Dec 22, 2005 12:32 PM
vofsar
