Platform: J-body
Throttle Position Sensor location
Old Oct 7, 2013 | 11:36 AM
wis2ohio's Avatar
Default Throttle Position Sensor location
Just wondering if anyone knows were the throttle position sensor is located on a 97 z24?
I believe this is my cars problems. When I am at a complete stop the RPM's drop below 500 and the car shuts off it also does it while I am driving, when i step on the gas the RPM gauge jumps up an down then stops it also does the samething after I try to move from a stopping position. Sometimes it acts like it isn't getting enough gas make it move so i am not sure what it could be.
Old Oct 11, 2013 | 5:39 AM
Jeff Collision's Avatar
The throttle position sensor will be located at the opposite end of the throttle plate shaft, it operates throttle plate in front of throttle body, you can find two Torx screws with it.
Old Oct 11, 2013 | 8:14 PM
wis2ohio's Avatar
Thanks. found that now any idea were the crankshaft position sensor is located? I found the camshaft sensor but can't find the crankshaft sensor.
Old Oct 19, 2013 | 10:35 PM
Kaosminis's Avatar
On 2.4L 4CYL VIN[T] It's located on front side of cylinder block almost dead center.
Equinox Owner
Jan 4, 2022 11:45 AM
malglot
Sonic (Aveo)
Jun 22, 2010 10:00 PM
lyrch
Feb 18, 2010 8:11 PM
txguykev
Dec 19, 2009 1:53 AM
