Platform: J-body
Timing on an 03 Cavalier
Old Feb 12, 2008 | 4:23 PM
BigAl88's Avatar
Default Timing on an 03 Cavalier
My friend decided to play mechanic and try to change the timing belt on his cavalier. He didn't put the #1 cylinder to tdc and just started dismantling things. Now his chain is off, the cams have rolled and he needs to fix it. How do i help him? Do i need to get the #1 cylinder to tdc and then rotated the cams until i get them to become stiff or something? I haven't dealt much with 4 cylinder engines yet. Any help would be appreciated
Old Feb 14, 2008 | 8:17 PM
ktm521's Avatar
Default RE: Timing on an 03 Cavalier
First bring the #1 cyl. to tdc. Both cam gears have a small hole in them if you need to line the holes up with the holes behind them. They make a special tool for it or you can use a bolt for both of them. Then install your chain.
jmms
HHR
Apr 17, 2015 4:22 AM
bobbie95poca
Sep 29, 2011 2:18 PM
dakota1820
Mar 5, 2011 10:06 PM
LetsGoMets78
Cobalt
Dec 18, 2006 2:48 PM
