Platform: J-body
Trouble with starting
Old Jan 12, 2013 | 1:54 PM
itzaboy's Avatar
Default Trouble with starting
The battery is charged up,starter turns over, I'm getting no spark(already replaced ignition coil assembly) and the compression in ALL cylinders is 30 psi or less. I'm running out of ideals, so yours would be helpful, Thank you
Old Jan 12, 2013 | 3:25 PM
kevinkpk's Avatar
Originally Posted by itzaboy
The battery is charged up,starter turns over, I'm getting no spark(already replaced ignition coil assembly) and the compression in ALL cylinders is 30 or less. I'm running out of ideals, so yours would be helpful, Thank you
30? I'd ask you to recheck the compression, or is this metric?
Old Jan 12, 2013 | 5:21 PM
itzaboy's Avatar
It is 30 lbs psi.
dozer157
Sep 8, 2009 7:32 PM
dfrail
Aug 15, 2007 1:06 AM
cobalt
May 30, 2007 6:27 PM
firerfighter521
Jan 8, 2007 9:29 PM
heil810
Dec 7, 2005 12:58 AM
