Platform: J-body
whats up with my cavalier
Old Mar 2, 2010 | 9:47 PM
jdmsmoker's Avatar
Default whats up with my cavalier
hey fellow cavalier owners i just bought a 91 cavalier its has a check engine light and i wanted to know how i could read the codes, also the there's no heat coming out the vents and the fan is not turning on if anyone knows what it might be let me know?
Old Mar 2, 2010 | 10:06 PM
gotstylez's Avatar
take it to autozone. they will scan it and tell you what codes are coming up. and go from there
Old Mar 3, 2010 | 12:56 AM
suzuki-guy's Avatar
Autozone is your best bet second option is the good ole paper clip.
http://www.instructables.com/id/How-...gine-Light-Fo/
Old Mar 3, 2010 | 1:35 AM
gotstylez's Avatar
i dont like the paperclip thing..lol.. i had a 89 transam i did that with.. it turned out i cant write a line and watch a light at the same time
Old Mar 3, 2010 | 10:17 AM
maxxman04's Avatar
no multi task option with you eh 'stylez?
Old Mar 4, 2010 | 2:00 PM
jdmsmoker's Avatar
I took it to auto zone they don't check it anymore found the service plug it has 3 wires going to it which wires should i jump? Now the car was running like it had a miss fire running rich i looked around and notices the vacuum hoses looked weird so i flipped them and the motor ran normal so i turned it off and started it up again but this time it took a little to fire up so i shut it off and tried again but didn't turn on. i notice the injector is not working is there a fuse or a relay that controls it?
Old Mar 6, 2010 | 12:46 PM
jdmsmoker's Avatar
I just tried two injectors hoping that my injector had fried or something but the injectors aren't firing ether. i grounded the blue wire which is the pulse that controls the injector and it sprayed gas . does any one know what could cause the pulse to weaken or can all these injectors be bad also?
Old Mar 6, 2010 | 3:36 PM
jdmsmoker's Avatar
i figured out what my problem was with the injector the wires were repaired before and the blue wire came loose so i hooked it up and it fired up, so now i have to figure out the how to read the codes and find a code list?does any one no what the spark plugs are suppose to be? the hood says 35 but couldn't drive the car at all.ac delco says 45 ran better but the car falls on its face every time i floor it, i pulled the plugs still running hot. Already gaped them at 50 and it seems like it still running to hot, im just going to keep opening them until it starts running rich hopefully i can figure it out that way
Just 1 More
Aug 27, 2013 2:50 AM
shawnjohn
Jul 27, 2006 11:47 AM
tatman
Apr 26, 2006 1:58 PM
bigchevy
Mar 16, 2006 1:38 PM
not a car guy
Feb 8, 2006 3:40 AM
