Platform: J-body
Where and how to run amp wire 94 cav?
Old Sep 1, 2011 | 9:54 PM
Lymsleia's Avatar
Default Where and how to run amp wire 94 cav?
As the topic implies. Im hoping to hook an amplifier up in my cav. Its the 94 4dr sedan. Its nothing huge. Its a 500w amp and i know how to wire it all up. Just installed a new deck to replace stock **** brick that came with the cav. But...i cant figure out where to run the wire from the battery through the firewall. Through various searches i saw some bits about cutting through the rubber grommet around your steering column and being able to shove the wire through there. But that is a moving part and from the inside under my dash it sa tight fit theres no way my wire would fit even if i did get it through from the engine side. If anyone has any experience here id love to know.
Old Sep 11, 2011 | 9:40 PM
spedaleden's Avatar
You can take a drill with a 1/8 inch drill bit and drill a pilot hole 1/4 of an inch to the right or left of the grommet. Look for the bit on the firewall from the engine compartment. If all looks good make hole for the size of the wire that you are running. If the hole is not right fill with silicone.
Hope this helps
mattcotools
19
Jul 13, 2011 9:35 AM
Craven Moorehead
Mar 13, 2008 2:16 AM
Vanshmack
Nov 25, 2007 12:26 AM
nova101mm
Mar 21, 2007 1:13 PM
ralphtrent
Jan 5, 2007 12:17 PM
