1976 Camino th400 not shifting into 3rd
Old Apr 24, 2022 | 3:34 PM
Ramirez248's Avatar
Default 1976 Camino th400 not shifting into 3rd
Recently purchased 76 El Camino shifts from 1st to 2nd but does not shift into 3rd . Vacuum modulator hose is connected to left passenger side port which reading says the line should not be connected to carburetor . Only intake fitting I see is in the rear which is connected to brake booster . If I tee that off with transmission vacuum would that possible fix no 3rd gear or use back or carb for brake booster and get a new fitting for transmission Vacuum ? Thanks
rrickerman
Sep 2, 2018 2:20 PM
Russ Hayes
11
Sep 15, 2017 3:12 PM
tCan
Chevelle & El Camino
Nov 13, 2011 11:25 AM
J0386
Aug 6, 2011 2:50 AM
Berend_Smit
Oct 22, 2007 12:40 PM
