69 Chevell Brakes
Old Apr 22, 2010 | 1:36 PM
preston_green's Avatar
Default 69 Chevell Brakes
I have a '69 Chevelle Malibu with 307 Automatic. It also has front drum brakes. When I apply the brakes it pulls to the left pretty good for a split second then doesn't pull so much. I've had the drums off and everthing looks good. All the brakes are adjusted the same. ie the shoes are adjusted so they barely touch the drum when I cleaned them and put the drums back on. I've read that the distribution block on the frame in the front is only a distribution block and has nothing to do with delaying fluid to the back brakes like it does on systems that have front disc brakes. In other words the distribution block is just a place where the line from the master connects the 2 front brakes lines. I'm not totally convinced my problem is the brakes. My question is "Could something wrong with the front end be causing this sudded jerk to the left when I apply the brakes?"
Any help would be appreciated.
Thanks
Old Apr 22, 2010 | 6:58 PM
therewolf's Avatar
Hi preston_green,
Welcome to the Chevy forums.
It could be a few things.
First, are you certain the lines have been thoroughly bled? Might be a small bubble still in one line which has to crush before uniform pressure can be properly applied.
Could be something's loose, shot, or unlubricated in the control arms or steering rack which went unnoticed before when the brakes were less than optimum. A careful visual check of all your suspension components is in order. A bad lower ball joint or slightly bent tie rod could be your culprit.
Best of luck. Keep us posted.
JRich_taco
Aug 31, 2013 12:16 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
Acardoctor
Corvette
Nov 26, 2005 7:23 PM
sixatd80
Oct 2, 2005 9:21 PM
southernrebel05
May 5, 2005 3:16 PM
