69 chevelle auto to manual swap questions
Old Aug 22, 2013 | 12:37 PM
malibutrev's Avatar
Default 69 chevelle auto to manual swap questions
I want to yank my turbo 350 and put in a Muncie. my question is, I have a 383 stroker with a 1 piece rear main seal and scat crank shaft. would the earlier Muncie with the 10 spline input shaft work? or would I need to go with the later Muncie or super T10 with the 26 spline input shaft. I want as easy of swap as possible with no machining on crankshafts input shafts etc. id like to stick with the 27 spline yoke if I can but will switch to 32 if necessary. I plan on using a stock bellhousing and clutch linkage. but I want a high performance clutch, as I plan on getting twin turbos in the future, and might be throwing 800+ hp at it. any clutch suggestions? any help would be greatly appreciated
Falconvan
Sep 6, 2013 7:30 PM
CapriceCraZy
Jul 3, 2013 10:06 PM
gmanuel11
Chevelle & El Camino
Nov 19, 2012 9:03 AM
rendrog18
Oct 19, 2007 12:55 AM
porterzcustomz
K5 Blazer
Jul 22, 2007 7:38 PM
