Center console
There is a lot of heat coming up through the center console. It’s so hot that the shifter is very hot. Is anything I can do to reduce the heat or eliminate it completely? It’s a 1965 chevelle Malibu convertible.... any ideas or thoughts are very welcome. Thanks
They make a stick on aluminum foil piece that would likely work to deflect the heat. Are you running headers? I am assuming no exhaust leaks, of course.
