Center console
Old Sep 11, 2019 | 11:24 PM
ms143's Avatar
Default Center console
There is a lot of heat coming up through the center console. It’s so hot that the shifter is very hot. Is anything I can do to reduce the heat or eliminate it completely? It’s a 1965 chevelle Malibu convertible.... any ideas or thoughts are very welcome. Thanks
Old Sep 12, 2019 | 12:29 AM
oilcanhenry's Avatar
They make a stick on aluminum foil piece that would likely work to deflect the heat. Are you running headers? I am assuming no exhaust leaks, of course.
Old Sep 12, 2019 | 7:41 AM
Open up the console or remove it to find where all this heat is coming from. I have never had that much heat coming from a center console. Are the floors solid?
Old Sep 12, 2019 | 8:32 AM
ms143's Avatar
Hi, thanks for replying to me. I just had the car restored including changing the column to the center console.
jxm9459
Dec 14, 2015 1:02 PM
TrackerGirl87
Sep 8, 2015 11:08 AM
Benno
May 4, 2014 11:47 AM
z71countryboy
Mar 24, 2010 2:51 PM
