gauge cluster housing
Old Apr 17, 2020 | 3:48 PM
shegseth's Avatar
Default gauge cluster housing
Where can I find a new or used gauge cluster housing for a 1968 El Camino without air conditioning? It is light green in the attachment.
gauge cluster housing in lt. green
Old Apr 17, 2020 | 4:09 PM
Try Ebay. I saw several there.
Old Apr 17, 2020 | 4:11 PM
shegseth's Avatar
will do, thanks!
Old Jan 2, 2021 | 9:30 PM
chevyboy@22's Avatar
Don't completely remember everything from taking one off, but yes, the nuts attached to the studs have to come off. I think there's a few smaller screws as well, but i'm not sure. The main thing is, work gently when you start to pull the housing out. It should come off very easily once everything is off. On the back, you'll have to disconnect your speedo cable and the large plug that fits into the circut board. I'f you're removing it completely, there'll be a few other smaller things, like the wire running to your shift indicator, conections for your headlight ***, possibly some oof the idiot lights. Just be gentle and don't pull too hard until you're sure everything is disconncted.
bigge31566
Aug 13, 2013 1:10 PM
chevyc1500
May 10, 2013 4:01 PM
joshr84
Feb 11, 2012 6:54 PM
rjhewitt78244
Aug 19, 2011 11:23 AM
willie1155
May 17, 2009 10:28 PM
