hoping someone can help
Old Aug 15, 2008 | 10:03 AM
Sole_Survivor's Avatar
Default hoping someone can help
Ok I have a 1981 Chevrolet el Camino with a 350 in it.
lately its been cutting out on me.I first thought it was the battery or something but it only does it at slow miles.Like I'll be driving and it'll be fine till I hit a stop light or a stop sign then it dies on me.I'm not sure exactly what the problem is.So any help would be appreciated.
Old Aug 15, 2008 | 11:20 AM
old dog's Avatar
Default RE: hoping someone can help
check the fuel filter ,and i guess you have plenty of gas in it ? is this tbi or carb ?a little more info .
Old Aug 15, 2008 | 2:10 PM
its a carb with a manual choke I adjusted the carb earlier it idles a little nicer but still keeps dying on me.I replaced the fuel filter less than 2 months ago.I have about a quarter tank of fresh gas in it.It's weird though that only when I slow down does it start dying.
Old Aug 15, 2008 | 11:40 PM
old dog's Avatar
along with checking the vacume hose's check the float level ,and make sure it is not saturated ,check the weight .
Old Aug 17, 2008 | 11:32 AM
therewolf's Avatar
If the engine's got a lot of miles on it,(100k+), and it starts ok cold and runs but refuses to start hot, assuming the choke is not a factor, have a mechanic look at the heads. The valves on my old 350 only acted up when it was hot, as soon as it got cold, it was off to the races. I used to be terrified I'd accidentally turn the engine off, and be stuck for three hours. A compression test with the engine cold and hot should verify this problem before you decide to do any work.
Charlie Depot
Jan 3, 2014 10:42 AM
tiger4life
Jul 28, 2013 3:32 PM
ChisumTK
Jun 9, 2013 6:31 PM
chenzo
Mar 21, 2010 5:35 PM
guvner
Nov 24, 2008 10:17 PM
