SBC SWP PS Bracket Problem
Old Dec 16, 2012 | 10:40 PM
67elko's Avatar
Default SBC SWP PS Bracket Problem
Can't seem to figure out why the PS Gear Box I installed is in the way of each of these 2 different PS Pump brackets. Is there a 3rd? The pump may be later than 67 which is the problem?
Old Dec 30, 2012 | 6:56 PM
ProStreet67's Avatar
Try an aftermarket power steering pump bracket. The Chevelle & El Camino frames should be the same, atleast firewall forward. Im running a 632 engine and have zero issues with my power steering pump on my 67 Chevelle. I have the same exact power steering pump you have pictured. Ill check mine out tomorrow and get you some pics.
But with a small block, the engine is physically smaller and the pump will sit lower to the frame. However, in the past I have used a small block power steering pump mount in my Monte Carlo when installing a Big Block in the same car that had a small block originally with no issues as another example.
tone72885
Jul 25, 2012 2:13 PM
oopsman_09
Mar 15, 2010 9:09 AM
Toby T
Mar 3, 2007 11:43 AM
Toby T
Mar 3, 2007 11:35 AM
MWRacing
Feb 14, 2007 11:27 PM
