sbc 350 problem
Old Mar 14, 2010 | 11:01 PM
oopsman_09's Avatar
Default sbc 350 problem
I am having an odd problem with an older 4bolt main 350 that I plan on putting in a boat. Somehow I'm getting too much oil pressure at the filter thus blowing out the filter o-ring and spraying oil everywhere at idle. I have changed the pressure relief valve already, but still have the issue. It's starting to boggle my mind and I can't figure out why it is doing this. Any thoughts or experiences? Would really appreciate the help.
Old Mar 14, 2010 | 11:04 PM
maxxman04's Avatar
have you checked for cracks around the seat area on block? is the oil return to block passage clogged?
oh, and welcome to the forums
Old Mar 14, 2010 | 11:49 PM
oopsman_09's Avatar
thanks for the welcome
Well, I can blow through a hose all the way through the block. lol
Don't think the seat area is crack it actually pulls the o-ring out of the filter and pushes it out when it blows it.
Old Mar 15, 2010 | 9:09 AM
old dog's Avatar
Default filter
if you have replaced the oil filter adaptor with the reliegh valve in it ,double check that itis free and operatiog then the only thing i can think of is the oil pump valve spring piston is stuck ,or the spring has to much tension .
tone72885
Jul 25, 2012 2:13 PM
mike78olds
Mar 9, 2007 10:01 AM
sooburban
Feb 10, 2007 9:31 PM
Artemis Entreri
Jul 7, 2006 3:18 PM
