Soft brakes almost to the floor on my 87 Camaro.
Old Jul 18, 2020 | 1:52 PM
jbander's Avatar
Default Soft brakes almost to the floor on my 87 Camaro.
The system has been bled twice, Rear drum brakes have been adjusted(front has Disk brakes) Boost has been checked (holds pressure), check valve Ok. Push rod adjusted. New master cylinder. Bench bled the master cylinder checked out the proportioning valve(combination) , No leaks, Clear fluid. I put on the brakes to stop and the peddle goes down slowly to almost totally to the floor. I'm going to double check the new master cylinder tomorrow . Any thoughts on this any suggestions. Thanks everyone.
Old Jul 18, 2020 | 2:24 PM
kevinkpk's Avatar
If you don't have any external leaks, it's an internal leak. Yes you posted new MC, but that dosen't always mean good. I'd look back at that.
Old Jul 18, 2020 | 10:43 PM
jbander's Avatar
Pressure tested this Master Cylinder, -Internal leak?
Old Jul 19, 2020 | 12:15 AM
abs brakes?
Old Jul 19, 2020 | 11:01 AM
jbander's Avatar
3rd gen didn't have them yet, thanks for the suggestion
Old Jul 19, 2020 | 12:00 PM
kevinkpk's Avatar
Is the proportioning valve external? Watch the fluid level in the MC while operating the brakes as you normally would, it might tell you if the fluid is shifting around.
Old Jul 19, 2020 | 2:52 PM
when bleeding the rear...did you have good fluid flow out the bleeder or limited flow?
Old Jul 19, 2020 | 3:43 PM
jbander's Avatar
Really good flow
Old Jul 19, 2020 | 3:44 PM
jbander's Avatar
Originally Posted by tech2
abs brakes?
Shifting around ? what will I be looking for. The combination valve is right below the MC
Old Jul 19, 2020 | 5:14 PM
kevinkpk's Avatar
Is the fluid flowing to/from either chamber? I'd suggest it could be the proportioning valve.
