1979 250 I6 Running Rough
Old Dec 29, 2018 | 8:36 AM
KSBandman's Avatar
Default 1979 250 I6 Running Rough
Hello, my 79 250 I6 starts easily, but runs rough until it is warm, and seems to lack the power it should have. When shifting, I am hearing popping (but not a true back-fire). Upon shut-off, it “diesels” a bit (engine chugging while the key is off).
This engine has vacuum lines running everywhere, and I replaced obvious cracked and broken vacuum lines, checked the PCV valve (it is ok). The exhaust smells like all the fuel isn’t burning.
Any thoughts on the next steps? I thought about new plugs and wires. It has 67k miles on it.
Thanks in advance.
KSBandman
Old Dec 29, 2018 | 9:44 AM
kevinkpk's Avatar
What gas are you using, ethanol, etc.?
Old Dec 29, 2018 | 10:10 AM
KSBandman's Avatar
Default Ethanol?
Good question. I use 87 in eastern KS, which may have up to 10% ethanol. I will check. What issues arise with ethanol?
Old Dec 29, 2018 | 10:33 AM
kevinkpk's Avatar
Since you said it diesels when shut off, an engine/carb that old might not like what gas you are using. That would be the first thing I would look into. Rough idle might be something different, and I agree with replacing vacuum lines.
Old Dec 29, 2018 | 10:43 AM
KSBandman's Avatar
Thank you
Old Dec 29, 2018 | 11:16 AM
kevinkpk's Avatar
You might try a different heat range spark plug if you cannot up the octane on the gas, what part of Kansas?
Old Dec 29, 2018 | 12:51 PM
KSBandman's Avatar
Northeastern KS. 87 is Regular Unleaded. Can you recommend a “heat range?” Is this something an auto parts place would advise?
Thank you.
Old Dec 29, 2018 | 12:58 PM
Check for the proper operation of the choke and related items. Also check the timing of the engine.
Old Dec 29, 2018 | 1:20 PM
KSBandman's Avatar
Thanks.
Old Dec 29, 2018 | 1:21 PM
kevinkpk's Avatar
What plugs are in it now, and are these the same direct replacement? Does the idle change with air temp, and as suggested by oldchevy, when cold, is the choke plate closed?
