Fuel hose vs metal line?
Old Feb 21, 2023 | 8:14 PM
Velder's Avatar
Default Fuel hose vs metal line?
Hello All,
So in addition to rebuilding my carburetor, I am also replacing the entire fuel system, From the fill ports forward.
My question is: should I replace the original bent metal tubing, with a direct replacement, or with fuel hose? Obviously fuel hose would be both cheaper and easier to run, but will it effect performance?
Has anyone here ever done this or seen it done?
As usual any advice is greatly appreciated.
Thank you
Old Feb 22, 2023 | 2:08 PM
it won't effect performance to run rubber line. make sure its the correct ID. if you go this way use fuel line hose clamps vs the regular gear clamp. They fuel line for carb and one for fuel injected.
stilllearning6
Oct 27, 2020 11:18 AM
savatreatabvr
Jan 14, 2017 11:55 PM
tjokerst91
Aug 28, 2012 10:29 AM
RelicAte
Jul 7, 2012 11:15 AM
JLanzino
Nov 26, 2011 8:58 AM
