Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
07 Chevy Cobalt P062F Code
Old Nov 4, 2013 | 11:10 AM
jsjackson12's Avatar
New User
Awaiting E-mail Confirmation
Default 07 Chevy Cobalt P062F Code
I am having trouble getting rid of a code...P062F which is long term memory in the pcm. Which I change from a vehicle that was sending no codes. But after installing and reprogramming I am still getting the same code.
Old Nov 4, 2013 | 12:11 PM
Welcome to the forum...
Does the suspect PCM work in the donor vehicle without the error?
If so I would suspect a wiring or voltage problem to the PCM... might want to check all fuses and PCM connections...
Old Nov 4, 2013 | 1:42 PM
New User
Default 07 Cobalt
Yes the donor came out of a vehicle that had no codes. Checking the wiring and all grounds associated. Thanx
Old Nov 4, 2013 | 2:03 PM
But if you put yours in the other car does it work okay?
And if you put the borrowed one back in the other car does it work?
Trying to identify if your vehicle is taking the PCM out, if they both work in the other vehicle then you have a wiring issue most likely
Old Nov 4, 2013 | 3:16 PM
New User
Checked all grounds and the old pcm is definitely bad I believe because it is giving off a cpk code and memory failure. Could the internal EEPROM be an issue?
Old Nov 4, 2013 | 3:23 PM
New User
Default 07 Cobalt
It was a crank position sensor code
billhill5181
Cobalt
Feb 23, 2014 12:01 PM
samster35
Cobalt
Apr 10, 2013 10:33 PM
chevyfanatik
Sep 2, 2012 8:42 AM
mreggena
Aug 28, 2011 6:27 PM
69rrvert
Cobalt
Apr 28, 2011 9:42 PM
