Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
'07 Cobalt engine chatter.
Old May 3, 2024 | 10:30 AM
davidbraun57's Avatar
Default '07 Cobalt engine chatter.
It happens when I turn on the a/c . I've replaced the serpentine belt tensioner , I thought it was going bad . Still doing it . And it only happens above 25 mph. I can't find any answers anywhere else ! I've also replaced the a/c compressor - cheapest eBay one I could find . COLD a/c ! Just the chatter is bugging me . It just topped 300,000 mi. I had replaced the timing chain assembly - a year ago ? About that .
Old May 4, 2024 | 7:26 AM
Did you replace the serpentine belt? When you replaced the compressor, did you also replace the clutch assembly?
Old May 4, 2024 | 8:38 AM
Rednucleus's Avatar
You say it happens over 25mph. Can you reproduce iti n the driveway revving motor at different rpms?
Old May 4, 2024 | 11:46 PM
did the last a/c compressor seize or replaced bc the noise? change the receiver drier/accumulator? did you perform proper oil balancing, refrigerant charging by weight?
kylepaddock
Cobalt
12
Sep 15, 2016 4:40 PM
DonVanhugenstyn
Jul 28, 2016 4:28 PM
chevyaveoowner11830
Sonic (Aveo)
Jul 7, 2011 3:47 PM
MDTAHOE
Nov 24, 2010 8:02 PM
tripod
Sonic (Aveo)
Jan 3, 2008 10:34 PM
