Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
07 cobalt won’t starter won’t roll over
Old Jun 6, 2018 | 8:22 PM
Adam Mcleod's Avatar
Default 07 cobalt won’t starter won’t roll over
i drrove the car parked it over winter went to start it battery was dead replaced battery but starter still won’t roll all accessories work an nothing dims just turn the key and nothing checked fuses also all good
Old Jun 6, 2018 | 8:25 PM
theft light on?
Old Jun 6, 2018 | 8:28 PM
It comes on briefly then shuts right off
Old Jun 7, 2018 | 8:16 AM
there are 2 wires to the starter motor. one large from the battery. one small from the ignition. the small wire is power in start to close the starter solenoid. when closed, you should hear the solenoid click once. if you don't hear it click...check for battery voltage on the small wire.
Old Jun 7, 2018 | 11:22 AM
Will give it a try what should volt meter read
Old Jun 7, 2018 | 3:04 PM
The only click I hear is coming from the fuse box the bigger crk relay
Old Jun 7, 2018 | 7:34 PM
0volts in any position but start. with the key in start...full battery voltage.
& check the big wire at the starter solenoid...should have battery voltage at all times.
Old Jun 7, 2018 | 7:35 PM
bigger crk relay
the starter relay?????
Old Jun 10, 2018 | 11:57 AM
tim_cleaveley's Avatar
It’s the BCM. You will get intermittent, starting problems with this problem.
This is is a common issue on this car and people end up spending hundreds chasing started and electrical problems.
Next time the car won’t start, give the BCM on the passenger side below the radio a kick. I becha it will start right up.
Old Jun 10, 2018 | 4:46 PM
bcm can be ruled out in seconds. have someone turn the engine to start while you put your finger on the starter relay in the fuse box...if you feel and hear the starter relay click. the bcm is working normally.
