Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2005 cobalt running lean
Old Sep 3, 2017 | 4:08 PM
john18975's Avatar
Newly Registered
Default 2005 cobalt running lean
my 2005 cobalt 2.2 ecotec has a lean code i have done spark plaugs fuel filter cleaned maf replaced intake
Old Sep 3, 2017 | 5:17 PM
if its lean at idle but ok at 2500rpm...you have a vacuum leak...this leak can be anywhere between the maf and intake manifold. check the fuel trim at both speeds
if its lean all the time...check the fuel pressure
