Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2006 Chevy Cobalt ls 2.2 liter P2433 code
Old Feb 23, 2014 | 12:01 PM
billhill5181's Avatar
Default 2006 Chevy Cobalt ls 2.2 liter P2433 code
Ok. So I have had my cel on for quite some time now and decided it's time to get the yellow light out of my face. I am getting the P2433 code and have been researching the crap out of it but not having any luck. From what I understand it's sending out a high voltage signal to the ECM. It seems there is a Secondary Air Injection Sensor?? But when searching I am unable to find anything about a Secondary Air Injection Sensor. I'm thinking the sensor may be part of the check valve but not one hundred percent. Also could a crack in the line cause this code? (I don't think so but checking all ends.) If I need to replace the check valve then so be it but I don't want to spend $150 and that not being the issue. If anyone has ran into this problem before or has a solution it would GREATLY appreciated.
Thanks in advance!
mudrider
Aug 3, 2022 9:25 PM
Sky Traveler
Oct 19, 2014 6:34 PM
samster35
Cobalt
Apr 10, 2013 10:33 PM
supaman557
Jan 1, 2012 7:39 AM
atcfan
Jul 31, 2008 11:55 PM
