Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2009 2.2l p0013
Old Jul 31, 2014 | 3:04 PM
Default 2009 2.2l p0013
Daughters 09 cobalt is getting a P0013 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit...
Haven't had a chance to check it out yet, will check the connections and wire harness to the sensors first as well as the oil level as I understand that can also trigger the code...
Old Aug 3, 2014 | 9:50 AM
Checked the oil level and it was fine....
I pulled the engine cover off and found the wire harness looms were disintegrating falling a part , I removed the rotted wire loom and re-wrapped with insulated heat tape and left the engine cover off for the time being.
Daughter reports that the engine light is not coming on any more when she starts it in the morning...
I suspect that the wire loom breaking down was allowing for heat and interference maybe even shorting to happen. will monitor it for a week and see...
Here is the tape that I used..
http://www.summitracing.com/parts/mr...Y9caApHt8P8HAQ
Old Aug 29, 2014 | 9:47 AM
As a follow up to this post, the code came back intermittently over the past few weeks, I ordered a replacement exhaust cam shaft actuator (OEM) from Amazon ~$38 and replaced, cleared codes and will monitor...
If you need to replace either of the actuators, be sure to used compressed air to blow out the pocketed/countersunk area that the actuators sit in to prevent any debris from falling in to the engine....
Also a light coating of engine oil on the o-ring of the new actuator prior to installing will ease install and help prevent tearing of the o-ring while installing...
this is a very easy fix should you experience the failure..
Old Sep 1, 2014 | 4:12 PM
So far so good, it appears the exhaust actuator took care of it...
Here is the part number if its needed for the exhaust actuator
Genuine GM 12655421 Camshaft Position Actuator Solenoid Valve
Old Oct 13, 2014 | 7:49 PM
Well here we are about 6 weeks later and now a P0010, the intake actuator...
have part in hand and will replace, I had read that if one fails the other is not far behind... so replace them in pairs and be done... for the both of them total is ~$70 or ~$35 each for OEM off of Amazon...
GM 12655420 Camshaft Position Actuator Solenoid Valve for the intake, the connector is gray.
bigedusa
Jan 4, 2014 10:00 PM
73shark
Camaro
Aug 29, 2007 11:23 PM
74camarodriver
Jul 20, 2007 10:45 PM
khelmick
Mar 27, 2007 12:56 AM
torres
Camaro
Aug 31, 2006 11:33 AM
