2009 Chevy Cobalt 2.2L No Crank/No Start
Hello, I am Haley.
I have a 2009 Chevy Cobalt, recently I went to leave work and the car stalled twice and would not re-fire.
Trying to start the car, it intermittently primes the fuel pump, starts then stalls out. When it dies the screen reads Low fuel, power steering.
Cluster will spike up sometimes like it wants to start but wont, then a few more cycles of the key the fuel pump kicks on and cluster reads, then car fires up for a few seconds and then dies.
I have changed the Mass air flow sensor, ignition starter switch and swapped fuel pump relay with my A/C relay and still nothing. Also put a fuel pressure gauge on and read 42psi not running, then steady 60psi when I could get the car to fire. Plugged in code scanner and read Linking error. hooked up to another vehicle and it worked.
