Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2010 cobalt LT no low beams
Old May 18, 2017 | 7:21 PM
Jshow's Avatar
Default 2010 cobalt LT no low beams
i was about to replace the driver side headlight bulb on my cobalt when i noticed when ever i started my car my lights would just go strait to high beams no matter the time of day. so i replaced the bulb hoping that it would fix this issue but still my car goes strait to high beams. i only have the options auto and high beams. so now i only have High beams.
any idea why this is happening and how to fix it,
Old May 19, 2017 | 9:41 AM
the dtr lights run on high beam at reduced power until trigger by the ambient light sensor or manual light switch is turned to manual on.
to confirm, if you move the light switch to manual on...then move the lever to low beams...do the low beams illuminate or is there no light on low beam
Old Dec 3, 2025 | 12:39 PM
tntrick's Avatar
Exclamation same issue 2007 cobalt
I have similar issue with grandson's cobalt. No low beams or taillamps, only high beams and no taillamps. I can power probe fuses and get all to light up. DRL fuse has a contact issue and can't get it to light up anything. I test it with power probe and don't get a signal + or - . any help at all appreciated!
Pipewrench78
Sep 15, 2023 1:43 PM
Scott Sanders
Jun 3, 2019 8:56 AM
Andrei Sokolov
May 22, 2019 3:58 AM
RockinFX
Sep 13, 2015 7:51 PM
atvkid4eva
May 24, 2013 7:07 AM
