Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
2010 Cobalt LT o2 sensor locations and recommended replacement
Old Oct 8, 2019 | 2:23 PM
Michael Methot's Avatar
Default 2010 Cobalt LT 2.2 engine o2 sensor locations (Edited Found the parts I need)
(Edited for brevity found my parts)
Hey folks, sorry if this is already posted here but I'm having a heck of a time finding info on this subject.
Could anyone assist me as to where the upstream and downstream sensors are as well as confirm I have only 2 of them? Much appreciated!
Also wondering if I'm replacing them is there anything else I should check for damage from driving with faulty sensors for a couple of months.
Thanks for any help, and if you need more info to help let me know.
Old Oct 8, 2019 | 7:30 PM
there is 2 sensors. one before the cat (upstream bank 1 sensor 1) and one after (bank 1 sensor 2 downstream)
follow the exhaust manifold out to back and you will see the sensors.
as far a damage...what codes were setting? was the car misfiring? any driveability issues
If you were only getting dtc for 02 heater codes...you won't have damage.
Old Oct 8, 2019 | 8:15 PM
Hey muchos gracias for the help, but I have to ask, could you kinda clue me in as to where the cat converter is? Behind the block, a foot down or something? And Howe would I tell the before and after the cat in terms of orientation? I'm sorely lacking in knowledge on anything other than filters, oil and washer fluid.
The code was mentioned to me by a tech at a service center, so I'm not sure of the details. It's rough at idle, with a knock every 30 seconds or so, about a full second of hesitation when stomping the gas from stationary, and it's been about 5,000km since the check engine light came on that prompted the visit to said service center. Just able to afford the fix now.
Thanks again!
alan00
Jan 26, 2018 10:31 AM
Michael Hewitt
1988 - 1998 (GMT400)
Oct 5, 2016 7:51 PM
Slowboy
15
Aug 4, 2014 7:56 PM
jtv137
Astro
Jan 23, 2013 8:44 PM
fulltimer1
Sep 26, 2011 12:08 PM
