Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Blend door actuator armiture brokem
Old Jun 5, 2014 | 3:45 PM
08slobalt's Avatar
Default Blend door actuator armiture brokem
The blend door actuator arm for the temp blend door literally broke in half on my 2008 cobalt was wondering what the fastest way to remove my hvac ventalation box would be
Old Nov 6, 2014 | 11:45 AM
lawrence54's Avatar
08 Cobalt, heater/ac blend door actuator rod broke in half. is the blend door part of the lower heater box assembly or can it be replaced after disassembly.
Old Nov 6, 2014 | 5:54 PM
this probably won't help but here's what i know.
haven't done a cobalt but the actuators are the same as equinox models I have done. if equinox models, a tab on the end of the blend door fits into the actuator and is turned when the actuator moves. when the tab breaks the entire door must be replaced which involves removing the heater box.
gm has come up with a sleeve repair and special cutting tool for the nox models that cuts the repair time down from 7hrs to 1hr. I do not know if the sleeve will work for the cobalt.
Old Nov 8, 2014 | 8:16 AM
lawrence54's Avatar
Thanks Tech2, that's kind of what I figured. looks like a spring project, opened the door for heat now. waiting for warmer weather.
DaniGirl
Jul 23, 2015 6:14 PM
JoeCB
Uplander
26
Mar 11, 2014 3:28 PM
Jack
Sep 20, 2009 2:33 PM
2006trailblazer
Feb 24, 2009 1:58 PM
