Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Blower motor removal ??
Old Jan 31, 2010 | 8:57 PM
maddawg's Avatar
Default Blower motor removal ??
Got a noise coming from the blower motor, anyone ever remove one of these,
It looks difficult. any suggestions would be helpful.
Old Feb 1, 2010 | 4:06 PM
shawnvw's Avatar
Banned
Removal Procedure
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover heat stakes (1) with a small chisel.
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    Important: Cut through the case as straight as possible because the motor cup must be reused. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  5. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  6. Release the blower motor retaining tab and remove the motor from the cup.
Installation Procedure
  1. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case.
  2. Install the blower motor nuts (3).Tighten
    Tighten the nuts to 2.4 N·m (21 lb in).
  3. Attach the service ring (4) to the motor cup (2) with the screws (5) included in the kit.Tighten
    Tighten the screws to 1.8 N·m (15 lb in).
  4. Install the blower motor and service ring into the HVAC module using the screws (5) included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle.Tighten
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws.Tighten
  7. Connect the blower motor electrical connector.
Old Sep 4, 2012 | 8:06 PM
dsurmanek's Avatar
i bought a new blower motor with fan from 1aauto and it doesnt inclued the screws.... it came with the service ring though..... exactly what screws should i use?
Old Oct 5, 2012 | 3:03 PM
1ATony's Avatar
New User
Awaiting E-mail Confirmation
You can use 1/4" self tapping screws. Any hardware/automotive/Home Depot would have them.
Here's a video that might help you out too with changing this.
http://www.youtube.com/watch?feature...v=guuQwZnRRqs#!
jenniferhcody
Jul 22, 2014 8:20 PM
tack
Jan 2, 2014 11:06 AM
aeroclimb
Dec 3, 2006 9:22 PM
Bobsyouruncle
Oct 31, 2006 12:11 AM
