Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
changing coolant and trans fluid on 2.2l
Old Feb 5, 2011 | 8:57 PM
2wd-K5's Avatar
Default changing coolant and trans fluid on 2.2l
ok, out balt just got over 100k km and its time for a coolant change and trans fluid change, obiously i dont want to pay someone 250 bucks to do both when i can do it cheaper, but i have a few questions before i do it and please answer only if you know or have done this on a comparable vehicle (HHR, G5) ok as for the trans, is there anything i should be looking for out of the ordinary? does the torque converter have a drain?
and as for the coolant, should it be flushed under pressure? if i dont will it trap air pockets in these engines? im replacing with dex-cool and i am replacing the thermostat at the same time time, thanks for any help given
wep54
Nov 11, 2013 8:49 AM
John O
Mar 31, 2010 2:29 AM
bwaple
Mar 6, 2008 8:30 AM
mikey45
Aug 1, 2007 10:15 AM
