Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Check Engine Codes P2101 and P1516
Old Jan 14, 2018 | 11:25 AM
Cobalt2006's Avatar
Newly Registered
Default Check Engine Codes P2101 and P1516
Hello,
Need help!! I keep receiving the below two check engine codes on my 2006 Cobalt LT and the reading "eng pwr reduced".
P1516 - throttle actuator control module / throttle actuator position performance
P2101 - throttle actuator control circuit range / performance
The car shakes when first started and will not accelerate properly.
Can anyone tell me if you had these codes and what you did to repair?
Thanks
Old Jun 11, 2018 | 5:19 PM
tim_cleaveley's Avatar
What were the previous symptoms?
Did you do anything to the car before this happened?
any mods? Or cleaning the intake ?
or unplugging sensors/battery etc?
