Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Cooling Fan
Old Jan 14, 2014 | 2:58 PM
ladybug's Avatar
Exclamation Cooling Fan
I have a 2007 Cobalt LS and I am having problems with the cooling fan engaging. The fan does work, we removed it and connected it to another power source and it came on immediately. Fuses have been checked. Suggestions please.
Old Jan 15, 2014 | 5:23 PM
sledge.impy's Avatar
Fan relay?
Have you verified power at the plug end?
Old Jan 15, 2014 | 6:10 PM
ladybug Welcome to the forum...
I agree, check the relays for the fans at the under hood electrical box....
There may be two fuses and two relays... see attached pictures...
You might try just re-seating them first...
Old Jan 16, 2014 | 10:10 AM
ladybug's Avatar
Yes we have checked them also...thank you
Old Jan 16, 2014 | 10:12 AM
ladybug's Avatar
We checked the relay all the fuses and came up with nothing, all that was left is there is a bad wire somewhere but where is a whole different story...so to keep me from overheating the engine we have wired it through the fuse box so it only comes on when the car is started and to a toggle switch that i can control
soundguy925
Apr 19, 2007 2:52 PM
jbronc88
Mar 22, 2007 11:14 AM
ottawaventure
Aug 13, 2006 12:26 AM
ottawaventure
Aug 10, 2006 9:56 AM
xswinnyx
May 13, 2006 1:01 PM
