Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
directional signal reset
Old May 11, 2017 | 4:46 PM
mtwallet's Avatar
Default directional signal reset
I can't find the flasher for the directional signals on my 2007 Cobalt.
Mine will not clear after turn
old cars were simple,I haven't had a problem with a later model in years,all the fuses look good
Old May 12, 2017 | 8:13 AM
if the problem is the signals will not cancel after a turn...the problem is in the signal lever assembly on the steering column. Its either the part listed below or the part the switch plugs into.
http://www.rockauto.com/en/moreinfo....433735&jsn=471
