Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Front left wheel makes loud vibrating/grinding noise when I turn left
Old Dec 10, 2018 | 6:55 PM
brainy19's Avatar
Default Front left wheel makes loud vibrating/grinding noise when I turn left
I drive a 2008 Chevrolet Cobalt LT. For the past couple weeks, whenever I turn left going at about 40 MPH or faster, I would hear a loud vibrating/grinding noise. It's quiet when I turn right tho. The noise starts even if I make a slight turn (when changing lanes for example).
Any ideas what it may be? I suspect it is the wheel bearing, but I would like a 2nd opinion please.
Old Dec 11, 2018 | 12:31 PM
SBchevyfan's Avatar
Most likely a wheel bearing but could also be brakes. Pull the front wheels and check the wear on both sides to make sure the wear is even, not a hung up caliper. Any warning lights coming on?
Old Dec 12, 2018 | 3:58 PM
brainy19's Avatar
No warning lights
Old Dec 12, 2018 | 8:53 PM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
My vote is that it is a hub bearing
Old Dec 13, 2018 | 1:17 AM
brainy19's Avatar
Checking the brakes sound easy and I can take off the brake pads and brake disk to check the wheel bearings, but what signs are there that the wheel bearings need to be replaced?
Old Dec 13, 2018 | 8:36 AM
How many miles are on the odometer?
I did a search on google for "how to determine if a hub bearing is bad"
You might get your answers faster there, than waiting for answers here.
Old Dec 14, 2018 | 11:26 AM
SBchevyfan's Avatar
Very likely it's the bearings. You can grab the wheel with the front end off the ground and pull on it in different directions and check to see if there is any play. Also, don't just replace one bearing if that's what you decide to do. Make sure you replace both front bearings at the same time.
Old Dec 15, 2018 | 5:40 AM
I would also suspect bearing.
Old Dec 16, 2018 | 12:55 PM
brainy19's Avatar
Thanks for the feedback everyone!
