Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Losing electrical when starting car
Old May 21, 2015 | 10:05 AM
Northof55's Avatar
Default Losing electrical when starting car
I had my ignition replaced under the recall, but ever since then, I have experienced problems with losing electrical systems when starting the car. The engine turns over ok, so it's not a battery problem, but the everything else goes dead. However, the headlights do turn on. I have no power steering, no brakes, no gauges and no clock/radio. Could the replacement ignition also be defective? The dealership has been of no use in trying to resolve the problem.
Old May 21, 2015 | 12:40 PM
what time frame are we talking; this happening after the recall repair? immediately or the next day, week?
the brakes could not be effected by anything electrical unless you have the turbo or s/c cobalt which run a vacuum pump assist motor.
the only thing that comes to mind is if the ignition switch is indexed wrong; you will have power mode mismatches. this would occur immediately, not later that day etc.
Old Jun 2, 2015 | 9:36 AM
az-barnum's Avatar
Default Same Issue
Did you ever get an answer to your issue? I'm having the exact same problem!!
Old Jun 2, 2015 | 9:38 AM
az-barnum's Avatar
Just wondering if your problem was resolved. My cobalt is doing the exact same thing - it started last night....
little
Mar 16, 2015 5:31 PM
Eric Kropp
Sep 17, 2008 8:20 AM
lvegaskid1
Feb 3, 2008 10:43 PM
h8tobl8
Aug 26, 2007 1:53 PM
Matt Luke
Aug 24, 2007 8:09 PM
