Fuel Pump Disolution Confusion I'm losing
Old Aug 24, 2007 | 2:40 AM
Matt Luke's Avatar
Default Fuel Pump Disolution Confusion I'm losing
I just replaced my fuel pump and the vehicle is not starting. I know the pump was bad. There is about 5 gallons of Gas in the vehicle. Is there a fuse or relay that goes out when the pump does? I've been starting the truck when it won't turn over by hitting the tank with a rubber hammer ( while someone turns the key over). This has gotten me through till the pump finally dropped out. Can anyone suggest any options to take to get my vehicle running? Is there a vacuum issue I don't know about. thnx a mill!
Before I changed out the fuel pump. when the vehicle died on me. The gas gauge went all the way over to past full. After changing the fuel pump and new connector the guage still goes all the way past full when I try and start my truck.[X(]
99 Tahoe. 4 dr.
Old Aug 24, 2007 | 11:46 AM
John86's Avatar
Default RE: Fuel Pump Disolution Confusion I'm losing
wat yr, make, and model is ur truck?
Old Aug 24, 2007 | 12:42 PM
Matt Luke's Avatar
It's a 99 Tahoe. 4 dr.
Old Aug 24, 2007 | 4:17 PM
John86's Avatar
well do u hear ur fuel pump running when u turn the key on? when u installed the new style connector u may have blown the fuel pump fuse so i'd check that in the underhood fuse block. also check the f/p relay under the hood.
Old Aug 24, 2007 | 4:46 PM
Matt Luke's Avatar
i have no power going to the relay or to the pump . i can't seem to locate a fuel pump fuse...just the relay.
Old Aug 24, 2007 | 5:27 PM
Matt Luke's Avatar
Found the fuse and that bad bowtie is runnin! suckinn lil bit more fuel than I'd like but it's on!!!
THNX FOR THE INPUT!!!
Old Aug 24, 2007 | 8:09 PM
John86's Avatar
no problem. glad to help.
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
Aaron@Airlift
Aug 2, 2012 9:33 AM
hunter10220
May 18, 2011 8:37 PM
