Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Need Help !!!
Old Aug 1, 2012 | 9:19 PM
ravichandan's Avatar
Default Need Help !!!
Need help!!
I have chevy cobalt 2009 LT and engine check light was on and trouble code is P0171.. I did clear the code using OBD scanner.. want to know whether the code will appear back if problem still persists and need help to take next steps
Thanks !!
Old Aug 2, 2012 | 9:47 AM
If the problem persist the code will come back. P0171 is a lean mixture bank1. Possible causes are dirty MAF sensor, vacuum leak, PCV valve, EGR dirty, fuel filter etc.
Old Aug 2, 2012 | 12:21 PM
Thank you for your reply!! I will start by replacing MAF at Firestone...hope that resolves the issue... I will keep you posted
Old Aug 2, 2012 | 2:17 PM
kevinkpk's Avatar
O2 sensor.
be_Martinezr
Oct 6, 2014 10:19 AM
1stTahoe
Apr 19, 2012 9:44 PM
badabingman
Mar 4, 2009 8:26 PM
