Cobalt This sporty compact was faced with the difficult job of replacing the popular Cavalier, but whether the base model, or the supercharged SS is chosen, is has made for a great replacement.
Platform: Delta
Also Check out CobaltSS.net
Rollover Valve
Old Jun 27, 2018 | 5:16 PM
BlackLyon28's Avatar
Default Rollover Valve
I own a 2008 Chevy Cobalt-- Does anyone know if there is a way to fix the rollover valve in the gas tank without buying a new gas tank ?
Old Jun 30, 2018 | 10:56 AM
how have you determined its faulty? Extremely rare for it to be a problem. If your issue is slow to fill tank...its more likely to be a blocked evap vent path.
Old Jun 30, 2018 | 11:15 AM
Had it tested by a mechanic when they took the tank down to inspect for leaks, it will leak if tank is full and it stops leaking after driving it down to almost 3/4 tank. Do you think it's safe to travel 3000 miles like that ?
Old Jun 30, 2018 | 12:09 PM
leaking fuel is not safe. you can't fix it. the valves are built into the tank. new/ used replacement tank required.
