Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2017 Colorado Transmission Advice
Old Aug 27, 2022 | 7:42 PM
Mgski's Avatar
Default 2017 Colorado Transmission Advice
Does anyone have experience/advice with selling their Colorado with the hard shifting issue to offer? I had the truck in for a month of repairs (2017 model) and still have the hard shifting issue. They can’t seem to resolve it. I feel stuck with trading it in to Chevy and getting a different Chevy truck but I don’t really want this circus again. Prefer to move onto another brand.
Old Aug 27, 2022 | 8:36 PM
oilcanhenry's Avatar
What engine and transmission do you have on your Chevy Colorado?
Old Aug 29, 2022 | 7:52 PM
Mgski's Avatar
I have the LGZ engine; 6cylinder 3.6L V6.automatic transmission, 8 speed.
Old Sep 3, 2022 | 3:36 AM
I believe that the 8 speed transmission is the issue. It could be the torque converter, not the transmission. I am not an expert on automatics, but I'd drain and replace the fluid, which should be done just to get rid of the break-in materials.
Old Oct 27, 2022 | 12:21 PM
chevyboy@22's Avatar
  • An different sign would be if your 2017 Chevy Colorado transmission warning light is on.
  • Strange smells are a sign your transmission fluid is burning inside your components.
  • If you notice an odd noise or grinding sound when you shift gears or if you feel your gears catching when you change them then your transmission achievable needs more lubricant or something more hazardous could be at fault.
  • One of the most basic signs is when your transmission shifts gears but the result of those shifts are delayed.
Old Oct 27, 2022 | 7:41 PM
Mgski's Avatar
thank you. The issue I have is shifting between first and second gear. It doesn’t always happen but when it does it is a hard shift between those gears. It doesn’t happen regularly or with other gears.
Old May 15, 2023 | 12:06 AM
MIKES19COLORADO's Avatar
Depending On How Hard The Shifting Is, Good Luck Selling It , Did You Try Any Stop Slip Additives ? I Assume You Have Had A Flush Already.. Me Personally. I Would Just Trade It In
Mike39
Colorado
Nov 12, 2017 8:14 AM
Johnny Mayday
Colorado
May 3, 2017 11:23 PM
DerekShiekhi
Colorado
Aug 29, 2016 7:52 PM
