Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2018 Negative battery terminal
Old Nov 8, 2022 | 1:19 PM
Glitch's Avatar
Default 2018 Negative battery terminal
My current negative battery terminal correded and will not come off. My only solution is to cut the wire and install a new connector. For my new connector does it need to be the same one or can it be one of the generic ones that you can get anywhere?
I ask because on the current connector theres a second grounding wire attached and on a new generic one I wouldn't know where to put it. Any help is greatly appreciated.
I attached an image of what the current connector sort of looks like. The nut on the left is where the extra grounding wire goes.
File Type: pdf
Old Nov 8, 2022 | 2:50 PM
Welcome from Florida. You can use a generic terminal or get the exact one that you currently have. The extra wire can be connected anywhere there is a bolt or even to the same place you connect the main cable.
Old May 15, 2023 | 12:13 AM
MIKES19COLORADO's Avatar
Cool
Grounding Wire Can Be Screwed To Anything Metal.. Its Not That Critical
tcbedard
Aug 11, 2021 3:57 AM
lakedrifter
Jun 15, 2015 8:55 AM
leonguaquero
Jul 6, 2013 1:50 PM
rallensub
Aug 2, 2010 10:56 AM
Basildane
Sep 14, 2006 3:45 PM
