Chevrolet Colorado
Platform: GMT 350, GMT 31XX
2018 Coolant Temp Sensor
Old Mar 26, 2022 | 4:12 PM
ESJ's Avatar
ESJ
Default 2018 Coolant Temp Sensor
Hello all,
I have a 2018 V6 Colorado. I'm having intermittent issues with the coolant temp sensor. Randomly and rarely, when I start the truck the temp gauge stays buried on cool (doesn't move after the first initial gauge movements upon start up). The air conditioner only blows hot air and both radiator fans run up to full-speed. After a few engine start-ups it clears and works normally.
I located the sensor which is in a difficult spot to access (passenger head, front, low in the valley between the heads and obscured by the front of the intake manifold). I cannot get my hands onto the electrical connector to remove it. I feel that if I could get the wiring connector disconnected, I would then be able to get a wrench on the sensor. During my previous attempt at replacing it I gave up as it seemed I might have to take the intake manifold off to get to it with my bare hands.
Anyone tackled this yet? Is there a specialized tool that will allow me to pull the connector without having to take the intake manifold off?
Thanks
Old Mar 26, 2022 | 4:21 PM
oilcanhenry's Avatar
You need curved pliers is my guess. There is always a way, you just need to spend some money and use your instincts.
Old Mar 27, 2022 | 8:07 AM
This might help you. Remember to release the red tan before pulling the cable off with the pliers.
Impala-Ryder
Jan 15, 2020 4:09 AM
RGibson
Jan 21, 2017 11:04 AM
Railroadertwo
May 9, 2015 1:49 PM
MDTAHOE
Aug 24, 2011 8:12 PM
ZeeQuEight
Nov 1, 2007 9:17 PM
