Chevrolet Colorado
Platform: GMT 350, GMT 31XX
My darn headlights
Old Nov 19, 2006 | 8:33 PM
fudgehammer's Avatar
Default My darn headlights
Hi.
I have a question about my headlights on my 2005 Colorado. I am constantly getting flashed for my brights when I dont have them on. I see no adjustment screws. I'm I blind, dumb, or rightly confused? Thanks in advance for any help.
2005 Colorado
Old Nov 27, 2006 | 11:05 PM
BowtieBoy's Avatar
Default RE: My darn headlights
I think you should go outside (at night) and turn on your brights in you driveway. Then get out of your truck and look at them. Next turn off you brights to the headlights regular setting and go look again. Is there a difference? If their is but it's still too bright, then I would check to make sure you have the correct wattage bulbs in your headlights.
Old Dec 17, 2006 | 3:50 PM
jtrambo18's Avatar
I get the same thing in my 05 Colorado. Do you have your fog lights on?I noticed that was the main problem for me. If they still flash you, just start swerving at them, they tend to stop.
Old Dec 24, 2006 | 6:36 PM
eddy997's Avatar
the adjuster screw for up/down on the headlights isinfront of the radiator support under the hood, behind the headlight it's self. it's a long brass colored screw. there is also a crosshare molded into the plastic lens if the headlights. using a tape measure, determine the height of the crosshare on level ground. then while parked 20-30ft from a wall, measure the same distance from the ground as the crosshare on your headlight. mark that location, the middle of the brightest part of your headlight beam (shinning on the wall) should pass through the mark that you just made, if you still get "flassed" thenpoint the headlights down more.
jclee1014
May 24, 2013 2:19 PM
David_lee1993
Nov 1, 2012 11:06 PM
cheyenne4x4
Nov 20, 2010 8:32 PM
brian213
Feb 4, 2006 5:34 PM
